AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
3-way valve actuator orientation on isometric
4 REPLIES 4
LjubanL
970 Views, 4 Replies
Hi to all,
I have one question regarding to 3-way valve actuator orientation on isometric, its look like that plant 3d doesn't know where/position is/off the actuator (is it up down/north/west....).
also important information about version
So,
if I create 3-way valve and put hand wheel on this valve
and if i take a look on iso
orientation of hand wheel is completely wrong...
Please find in attachment gif of these problem.
so if anyone have these weird behavior please participate/help to this topic...
BR
Ljuban
4 REPLIES 4
rajendra.prajapat
in reply to: LjubanL
Please select the Part Type "Valve Body" and then try to generate isometrice.
If my reply was helpful, please click the "Accept as Solution"
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
sarina.desaeger
@LjubanL
Hello
Did you find a solution? I have the same problem when I create a 3 Way valve as a custom part. In this case there is no possibility to add it as a valvebody instead of a valve.
Update: The solution for me is to change the type to TYPE=VALVE-3WAY.
Kind regards,
LjubanL
in reply to: sarina.desaeger
Hi Sarina,
Its a really old post but tnx for interest.
You can find better analyze and some conclusion here
https://forums.autodesk.com/t5/autocad-plant-3d-forum/3way-orientation-actuator/m-p/10262419#M48691
BR
Ljuban
placek
As a solution for this topic can be to use for 3-Way valve the procedure for Multiport valves instead of the procedure for 3-way valves. Try next for 3-way valve:
Iso Symbol Type = VALVE-MULTIWAY
Iso Symbol Skey = MD??
(MDSC, MDFL etc.)
But, by default is the actuator NOT shown.
If you need actuator, you must edit IsoSkeyAcadBlockMap.xml, find next row:
However, I found, that the actuator was wrong directed in some cases in the ISO. You can try to change the actuator direction in the block MPVActuator to Z direction. Edit Block "MPVActuator", rotate graphic around X axis, so finally the actuator will be in  the direction of axis Z. This was solution for me, but, it maybe not works for 100% cases.
If someone will have better idea, I welcome your suggestions. Thank you.
Above steps are only workaround for me, maybe you find better.
Love Plant3D
Technology Administrators
