AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Labels on top of feature not displaying
3 REPLIES 3
randyspear6624
899 Views, 3 Replies
I have a shp file of points representing trees. I used an expression in the style editor to draw the drip line. However the labels only show if I choose "place next to feature". If I place on top with 0,0, they don't show.
Any help would be appreciated.
3 REPLIES 3
GOOD QUESTION! I'll be asking Autodesk support about that tomorrow. In the meantime, if you add the text as an element in the feature STYLE and stack it below your feature it should work:
Warren Geissler
Drafting Manager Denver Water
_____________________________________________
Please ACCEPT AS SOLUTON if this works
(...and doesn't melt your computer or cause Armageddon)
swt-gis
in reply to: randyspear6624
Use "place on top with 0,0".
Save layer to .layer-file.
Edit .layer-file with a text Editor:
Change these Option from true to false:
<CheckExclusionRegion>false</CheckExclusionRegion>
<AddToExclusionRegion>false</AddToExclusionRegion>
Add .layer-file to your map (e.g. drag&drop).
(See also the solution from this post: How to force AutoCAD Map 3D to draw a FDO label even if they overlap?)
Regards
Jens
randyspear6624
in reply to: swt-gis
Thanks, I found this solution earlier but couldn't figure out how to output to xml format.
However, adding as a symbol is a much easier work around.
Technology Administrators
AutoCAD Beta
