Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Grips bug with Map 3D 2018
thierry_prince
Message 1 of 64
thierry_prince
With AutoCAD Map 3D 2018 FR, a new bug has appears. It concern the grips use with several objects.
I post you a video to show the bug with an arc, but there is also some (different) problems with polylines (context menu does not appears after the first change), multi-lines, splines, and perhaps some other objects.
This problem does'nt exist with Map 3D 2017 FR and also not with AutoCAD 2018 FR.
I don't know if other language versions of Map 3D 2018 have the default.
I hope it will be solved ASAP.
Cheers.
Thierry
Replies (63)
Message 2 of 64
Alfred.NESWADBA
I don't see that issue with AutoCAD Map 3D 2018 English (on German Windows 10 x64)
Maybe you can try the same with another template file?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 3 of 64
braudpat
Hello "The Froggy"
+1 with Alfred !
1) No problem with ACAD MAP 2018 US/English Beta !
2) Maybe you could try (if it's possible) to replace the French DLL(s) by the US/English DLL(s)
BUT if the problem is on many different entity types ! I doubt !!
3) I use this method on ACAD MAP 2011 (Replacing French by US/English DLLs) for a major bug (NEVER corrected by Autodesk) with the Grips on MPOLYGONs !
4) So waiting ...
Happy WE, Regards, Patrice
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 4 of 64
O_Eckmann
Hi Thierry,
Same bug with MAP 2018 x64 french on Win 10 Pro x64 french
Olivier
Olivier Eckmann
Message 5 of 64
gcamus
Same with English US version.
Message 6 of 64
braudpat
Hello Gilles
Welcome to the Autodesk / AutoCAD Forums !
We are waiting for a specific Hotfix concerning the Bug with Grips on MAP 2018 English/French/...
Regards, Patrice (Ich bin ein Berliner)
Patrice BRAUD
Message 7 of 64
Thomas_Stuehle
thank you all for the heads up. This issue is forwarded to be solved code wise.
As a workaround, please deselect the arc in between, the issue appears in the video and on my side after stretching the vertex a second time.
Please have a look at the video for the workaround: http://autode.sk/2pAgHXR
Best regards,
Thomas
Your question got successfully answered? Then just click on the 'Mark as solution' button.
Thomas Stühle
Technical Support Specialist
Message 8 of 64
Alfred.NESWADBA
am I the only one, who does not have the problem?
In that case maybe the difference is that I have installed AutoCAD as well as AutoCAD Map 3D (and later Civil 3D too).
just my 2c, if that can help the development team ...
- alfred -
Alfred NESWADBA
Message 9 of 64
thierry_prince
No Alfred, your are not the only one.
But I think at this time there is no rule to know if it will work correctly or not.
We have a machine with AutoCAD + AutoCAD Map 3D on Windows 7 that has not the problem, but another machine with same AutoCAD + Map and also on Windows 7 has the problem.
Two machines with only Map on Windows 10 doesn't have the problem where several other on Windows 7 has it.
Perhaps it depends of Windows version or of what is already installed...
Cheers
Message 10 of 64
braudpat
Hello Alfred
1) So you have ACAD 2018, ACAD MAP 2018, ACAD CIVIL 2018
- ALL in US/English, I presume ?? or German ?? or a MIX ??
2) Please in which order did you install these 3 softwares ?
Regards, Patrice (Ich bin ein OTX Berliner)
Patrice BRAUD
Message 11 of 64
Alfred.NESWADBA
Well, I do have a lot more software on that system
  • AutoCAD 2014 German + English Language Pack
  • AutoCAD 2015 German + English Language Pack
  • AutoCAD 2016 German + English Language Pack
  • Map 3D 2016 German
  • Civil 3D 2016 German
  • AutoCAD 2017 German + English Language Pack
  • Map 3D 2017 German
  • Civil 3D 2017 German
  • AutoCAD 2018 German + English Language Pack
  • Map 3D 2018 English ==> "English" ... that happened, because that was the only time I have let Autodesk Desktop App install something automatically, not sure why this App thought I want to have the English version installed ... and so I do have a language mix in 2018 products
  • Civil 3D 2018 German
Always from old to new, and from less functionality to most functionality.
So I started with AutoCAD 2014 .. 2015 .. 2016 (first AutoCAD, then Map3D, then Civil3D) .. 2017 (first AutoCAD, then Map3D, then Civil3D) then 2018 (first AutoCAD, then Map3D, then Civil3D)
Map3D 2018 was the only software which I did not install by first using browser-download and then install from local files, Map3D 2018 was installed by Autodesk Desktop App.
All sitting on top of Windows 10 x64 (1607) German + nVidia GTX 970M (driver version 376.74)
- alfred -
Alfred NESWADBA
Message 12 of 64
jporter
@Thomas_Stuehle, just an FYI there is a similar grip issue with polylines as well, and both issues (the one in your video and mine) are happening in Civil 3D as well.
Check out this video:
Jason Porter
ASTI Civil Solutions Technical Advisor
www.asti.com
Message 13 of 64
Alfred.NESWADBA
Can't reproduce that issue with multigrip function "add-vertex".
My video is attached.
- alfred -
Alfred NESWADBA
Message 14 of 64
jporter
@Alfred.NESWADBA. . .very interesting.  I just tested in my Map 3D 2018 (same build) again to make sure I'm not crazy and I have the issue.  I had several co-workers test as well and they all have the same issue as I do in my video.
So what's different?  I've not modified anything except the black background on my end.  I see you have some toolbars.  Did you happen to migrate your workspace forward?  I wondering if that somehow migrated the code forward.
Jason Porter
www.asti.com
Message 15 of 64
Alfred.NESWADBA
Yep, own additional applications, but not loaded at this state.
I never use migration
I'm working with Window 10 Enterprise, 64bit, German
My main customizations are
  • operating system ==>  %TMP% and %TEMP% points to a different folder for the operating system (C:\TEMPSystem\WinSystem\ and C:\TEMPSystem\WinUser), so I avoid that the operating system creates temp-files in the users folder.
  • AutoCAD (and verticals) ==> use subfolders of the above temporary folder for all AutoCAD internal folders that use temp or log by default (==>  C:\TEMPSystem\ACAD\)
  • AutoCAD is set to use templates with units Meter (but I can't reproduce your issue with ACAD.DWT too, which is set to inch)
  • Well, minor modifications are done, so I have attached an ARG-file as well as the output of SYSVDLG if you want to test it (or for Autodesk if they want to compare things)
  • But as it's a development system, the basic applications is running clean of any automatically loaded tools or so.
- alfred -
Alfred NESWADBA
Message 16 of 64
jporter
I too don't ever migrate my settings.  I don't see how your customizations may effect the gripping.  I'm on a Windows 8.1, 64-bit system.
I used your ARG file and I got the same results. . .I still can't add multiple vertices.
Jason Porter
www.asti.com
Message 17 of 64
kboldt
jporter, I am in the same boat as your screencast. I will get the context menu for editing a grip once, and then after I use it once, I have to escape to remove the selection, and then re-select the polyline, at which point I can complete an "add vertex" etc., but again, only once.
I am on Windows 10 64bit, using Civil 3D 2018 with no modifications or migrated settings.
Message 18 of 64
braudpat
Hello
So please Autodesk, we will get YES or NO a Hotfix/Patch for this strange bug ??
Thanks, Regards, Patrice
Patrice BRAUD
Message 19 of 64
albionpjl
It's a month later. We've just upgraded to C3d 2018, and found this bug.
This is a massive nuisance. I use the grips menu all the time and having to escape between each edit is a PITA.
Is there any chance that Autodesk may fix this bug?
C3d 2018 (Ribbon off, toolbars on, cuix imported from 2017, previously imported into 2017 from 2016 etc), Win7 pro.
Message 20 of 64
Has there been any progress on this?  I'm having issues I'm assuming are related to where if I select more than one object, MOST of the grips won't show up, I don't get a menu on hover and if I grab a grip it acts like snap is on when it's not.
