Grips bug with Map 3D 2018
thierry_prince
Message 1 of 64
thierry_prince
With AutoCAD Map 3D 2018 FR, a new bug has appears. It concern the grips use with several objects.
I post you a video to show the bug with an arc, but there is also some (different) problems with polylines (context menu does not appears after the first change), multi-lines, splines, and perhaps some other objects.
This problem does'nt exist with Map 3D 2017 FR and also not with AutoCAD 2018 FR.
I don't know if other language versions of Map 3D 2018 have the default.
I hope it will be solved ASAP.
Cheers.
Thierry
Replies (63)
Message 61 of 64
Alfred.NESWADBA
[deleted, sorry]
Alfred NESWADBA
(not an Autodesk consultant)
Message 62 of 64
Alfred.NESWADBA
[deleted, sorry]
Alfred NESWADBA
Message 63 of 64
DMNH
Community Visitor
Community Visitor
is this update not available anymore. I got a new computer at work and now I have the grips issue again and can't find the update to save my life. Anything I find about it just brings me back to this thread!!!!!
Message 64 of 64
jporter
Are you still using 2018?  If so, then no, the updates are not available anymore.  Autodesk only supports the current version plus three versions back. Once they stop supporting the software they pull all updates and no longer release new ones.  When Map 3D 2022 was released Map 3D 2018 fell off the supported list.  Now Map 3D 2023 is out and Map 3D 2019 is no longer supported.
If you're on subscription and still using 2018 software need to upgrade sooner rather than later.  You are in violation of your license agreement with Autodesk.  Legally, you can only use the current version plus three back (though there is documentation that five back is legal to have installed as well, but they only support three versions back).  Regardless, three or five, 2018 is not legal to have installed anymore.
Hope this helps,
Jason Porter
ASTI Civil Solutions Technical Advisor
www.asti.com
