Grips bug with Map 3D 2018
thierry_prince
Message 1 of 64
thierry_prince
With AutoCAD Map 3D 2018 FR, a new bug has appears. It concern the grips use with several objects.
I post you a video to show the bug with an arc, but there is also some (different) problems with polylines (context menu does not appears after the first change), multi-lines, splines, and perhaps some other objects.
This problem does'nt exist with Map 3D 2017 FR and also not with AutoCAD 2018 FR.
I don't know if other language versions of Map 3D 2018 have the default.
I hope it will be solved ASAP.
Cheers.
Thierry
Replies (63)
Message 41 of 64
I have not been able to install the updates just yet for our deployment. We are hoping to resolve some other bugs along with the hotfix  at the same time this week.
Thank you for your help. I will keep you updated.
Message 42 of 64
@jporter The plus signs still appear over the polylines even after upgrading to Civil 3D 2018.2 . And we can only add one vertex before hitting esc to redo the process.
Product Version: 12.0.1386.0 AutoCAD Civil 3D 2018.2 Update
Built on: O.161.0.0 AutoCAD 2018.1.2 Update
O015AK Autodesk AutoCAD Map 3D 2018
8.0.100.0 AutoCAD Architecture 2018
Message 43 of 64
jporter
It's NOT the Civil 3D update you need to install.  It's the Map 3D update.  In the link @Thomas_Stuehle provided (Grip issue with editing polyline and arcs in Map and Civil 2018) the solution states:
Solution.pngThis is what your prodcuct version and build should currently read:
Jason Porter
ASTI Civil Solutions Technical Advisor
www.asti.com
Message 44 of 64
Yes, you are correct. I just installed that update and the issue is gone. Thanks so much!
Message 45 of 64
@jporter
Me too. Same issue on Civil 3D 2018!
It is not efficient to escape out of the PL and select it again.
Hopefully this get fixed soon.
Message 46 of 64
jporter
@Anonymous, it has been fixed.  Check out message 30 of the discussion by @Thomas_Stuehle:Grips Hotfix.png
Here's the link:
https://knowledge.autodesk.com/support/autocad-map-3d/troubleshooting/caas/sfdcarticles/sfdcarticles/AutoCAD-Map3D-Stretch-vertex-for-arcs-has-an-offset.html
Jason Porter
www.asti.com
Message 47 of 64
donna.logan
Hi all,
Has anyone found that even after installing all updates, this is still occurring?
I'm all up to date (in fact, re-installed Civil3D2018 for another reason) but still need to de-select
and re-select plines to remove vertices. Thanks.
Message 48 of 64
jporter
I've assisted lots of folks with this fix and not one has come back stating the issue returned or was not fixed.
Now you said you've installed all updates, but verify the build as well.  This is mine:
Jason Porter
www.asti.com
Message 49 of 64
Alfred.NESWADBA
No.
Can you please start command _ABOUT and show us a screenshot of that dialog?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 50 of 64
donna.logan
Thanks for the quick reply!
Message 51 of 64
Alfred.NESWADBA
thank you for your screenshot!
But sorry, none of the 3 modules are updated, not AutoCAD, not Map3D, not Civil3D.
That is how your dialog should look about for Civil 3D 2018:
- alfred -
Alfred NESWADBA
Message 52 of 64
donna.logan
I may be wrong, but is this not an indication that my updates are installed...Each one says the same thing (AutoCAD, AutoCAD Map3D etc)
Message 53 of 64
jporter
Install the updates needed for AutoCAD, Map 3D, and Civil 3D:  https://www.asti.com/where-are-do-i-find-updates-to-my-autodesk-software/?preview=true&_thumbnail_id...
Jason Porter
www.asti.com
Message 54 of 64
Alfred.NESWADBA
Or you are not assigned to receive and install updates.
Contact your contract manager, he is the one who can give (or remove) permissions.
Also necessary: you need to have an active subscription.
- alfred -
Alfred NESWADBA
Message 55 of 64
jporter
I’ve found that the desktop app does not always work.  Read that link I provided above.
Jason Porter
www.asti.com
Message 56 of 64
donna.logan
Thanks so much to both of you, Jason and Alfred!
It's now working as expected.
As you mention on your article, Jason I was not aware of this autodesk webpage.
Message 57 of 64
rsauerYSAX6
@Thomas_Stuehle I have come across this issue with a freshly installed Civil 3D. Autodesk Desktop app claims that AutoCAD, AutoCAD Maps and Civil 3D are all up to date (the app says Civil 3D is on version 7.0.15.17). I am able to edit multiple vertices on a polyline in AutoCAD but I am not able to in Civil 3D or Map 3D. There is no hotfix attached to the article linked, instead the solution is to update the software, which is not possible, as the desktop app does not specify any updates necessary. I'm operating with English language settings.
Message 58 of 64
Alfred.NESWADBA
Are you on subscription?
Can you please start Civil 3D, then command _ABOUT and show us your screenshot?
- alfred -
Alfred NESWADBA
Message 59 of 64
rsauerYSAX6
For some reason Desktop App is not showing me pending updates that I need. My organization's IT staff manually updated Civil 3D and the bug has been resolved.
Message 60 of 64
jporter
The desktop app does not always work.  I've seen some situations where it's reporting you need an update when you have the already installed and others where it says you're up to date and you're not.
First check your build (type in ABOUT at the command line) and compare it with the others that have already been posted in the discussion.  Then, if you need updates, find them in your Autodesk account.  I discuss this here in this blog:  https://www.asti.com/where-are-do-i-find-updates-to-my-autodesk-software/?preview=true&_thumbnail_id....
Jason Porter
www.asti.com
