AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
create a table in the drawing that displays the bearing and distance of lines
1 REPLY 1
pcorunFNGTG
976 Views, 1 Reply
I am using AutoCAD Map 3D 2017.  I have a unique process that I need some help with.  My process is kind of the reverse of most of the posts I have found.  What I need to do is take a shapefile and import the points into AutoCAD Map.  Then connect the dots with a line/polyline.  I have this process figured out.  The next step is what I need help with.
Once t he line/polyline is drawn, I need to take each line segment and tabulate them on the drawing.  The columns of the table would be:
LINE SECTION     BEARING       DISTANCE
Bearing is in the N40d30'22"E format and the distance is in feet.
Is there a way to select these line segments and create such a table like you can do with points in AutoCAD Civil 3D?
Thanks for your help in advance.
Pat.
1 REPLY 1
Murph_Map
in reply to: pcorunFNGTG
You could use data extract to create an excel file then bring that in as an autocad table.
Murph
Supporting the troops daily.
”Boost
