I am using AutoCAD Map 3D 2017. I have a unique process that I need some help with. My process is kind of the reverse of most of the posts I have found. What I need to do is take a shapefile and import the points into AutoCAD Map. Then connect the dots with a line/polyline. I have this process figured out. The next step is what I need help with.
Once t he line/polyline is drawn, I need to take each line segment and tabulate them on the drawing. The columns of the table would be:
LINE SECTION BEARING DISTANCE
Bearing is in the N40d30'22"E format and the distance is in feet.
Is there a way to select these line segments and create such a table like you can do with points in AutoCAD Civil 3D?
Thanks for your help in advance.
Pat.
You could use data extract to create an excel file then bring that in as an autocad table.
