slam allekom .
attached file/ with arabic font/ if i plot to my ploter its ok ./ if i plot vea outocade pdf pc3 the letters not conected/ there is no glue btween them // why ?plz try it / i checked the difrence btween confegration of my ploter ant aut-pdf ploter /and some thing missing / i red a pit about it/it seems conected to these 2 / how can i install them in aut pdf plooter ??? is it posseple .
i dont want external pdf ploter .
thank u
ur help lord
Solved by john.vellek. Go to Solution.
Solved by pendean. Go to Solution.
Solved by WarrenGeissler. Go to Solution.
Make sure of the setting shown here:
Warren Geissler
Drafting Manager Denver Water
_____________________________________________
Please ACCEPT AS SOLUTON if this works
(...and doesn't melt your computer or cause Armageddon)
hi' and thank u .
i traied all the options possible ' doesnt wooork.
did it work for u ??
It worked for me - see my attached pdf.
Warren Geissler
so cute .... know im sure u have no arab rotes .
its seperated (the letters) . its wrong .
attached 2 p d f . no 4 ok no 3 not ok .
this proplem need jenous to solve it .its so known .all the arab ingeneers suferd from it ... how can i write to outocade companey ??
the solution is in changing the confegration of the ploter < the ok sheet i print it with external pd f ploter / but i cant use it becouse i cant confequre the paper size in it .
with god love
slamat
انت على حق. ليس لدي جذور عربية، ولكن لدي ترجمة جوجل
You can post more directly to Autodesk at the product feedback portal >>HERE<<
مع حب الله
Warren Geissler
waw ...semmes so nice . :))
can u help me to add these 2 to another pc3 plooter ? how can i do it ??
thank u
You cannot add those options to the printer properties. If they are not available, then look into the CUSTOM PROPERTIES:
Warren Geissler
salam aleekom .
i have no proplem sending drowings to my hp ploter. the sheet and the font get out perfuct / thanks god .
the proplem when i need the dwoings as pdf sheet. to send vea meal or something .
so i use outocade ploter to pdf then the font get wrong . and all the leters seprated .
there is these 2 confegrations that can make it wright / they are not in the outcade pdf plooter and i dont know how to change it .
help
thank u .
attached ziped file with diffrent options of fonts and it all get wrong in pdf.
HI @nmzareeb,
I have found that the Capture fonts options does work with some SHX files but not all. I have logged this issue with the team in the past. The Product Feedback page as suggested by @WarrenGeissler is a great way to bring additional attention to the issue.
hi again .
i do wrote a fedback about it as wareen suguest . thank u . i hope it will help .
the text u sugest is true the only arab text ploted wright in the pdf ploter .but its so bad .the leters grafecs (the midle leters and the end leters ) not good . check plz the end leter in the word ... its not the same .. and if want to change it need to do shift all the time i hate it its bad font not easly readable ........ im sorry about my inglesh.
HI @nmzareeb,
I agree that the font is not great. So far though, it is the only one that I have found that plots close to correct. I am still watching fore others.
waht ue axplanation to it ?? what should be speachl in this font ?? and is it sign thats the proplem have nothing to do with the ploter confegration .
check plz the diffrence btween the difntion of the diveses in graphics list in bdf external ploter or any hp ploter and the potocade bdf ploter . do u think we can add it ???
raster image and true type text . ?!!
