AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Convert STP file to DWG
4 REPLIES 4
10534 Views, 4 Replies
Is there any way to convert a STP file to DWG so I can open the file and copy the perimeter of an object. I work in 2D and only need the Perimeter to fabricate a flat cover for the product.
4 REPLIES 4
pendean
That's a full AutoCAD feature in the IMPORT command, not found in LT.
Ask the STP file creator to change the format for you.
Thanks for the response
T. Lynn Reavis
[Description: cid:image001.jpg@01CABB77.42803040]
Product Manager of Pre-Engineered Pools
e-mail: Lynn.Reavis@poolcorp.com
6431-J Reames Rd
Charlotte, NC 28216
Phone: 704.509.5741
Fax#: 704.509.5771
Cell#: 704-287-6248
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail.
in reply to: pendean
Is there anyway to convert an STP file to an OBJ file? Thanks.
pendean
You can do that in SolidWorks I believe.
If you don't have that, there are conversion websites out there that can do it or you, most are not free.
Technology Administrators
