AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Unable to set support file search path with PackageContents.xml
5 REPLIES 5
673 Views, 5 Replies
I'm unable to set support search path for AutoCAD LT.
Here is the code
<?xml version="1.0" encoding="utf-8"?>
Name="CAD4Test"
Description="CAD4 Test">
<CompanyDetails Name="HBS" />
<RuntimeRequirements OS="Win32|Win64" Platform="AutoCAD*|ACLT|ACADLT" SeriesMin="R18.2" />
<Components Description="CUI">
<RuntimeRequirements SupportPath="./Contents/;./Contents/Resources/" OS="Win32|Win64" Platform="AutoCAD*" SeriesMin="R18.2" />
<ComponentEntry AppName="CAD4Test" ModuleName="./Contents/cad4.cuix" AppDescription="Sapa CAD4" />
</Components>
<RuntimeRequirements SupportPath="./Contents/;./Contents/Resources/" ToolPalettePath="./" OS="Win32|Win64" Platform="ACLT|ACADLT" SeriesMin="R18.2" />
<ComponentEntry AppName="CAD4Test" ModuleName="./Contents/cad4.cuix" AppDescription="CAD4 Test" />
</Components>
</ApplicationPackage>
It works in AutoCAD full version but in AutoCAD LT 2020 only the cuix file is loaded.
For debug reason I tried with ToolPalettePath and this works in AutoCAD LT 2020.
Am I doing something wrong or is it a bug in AutoCAD LT 2020?
5 REPLIES 5
steven-g
I could be wrong on this, but my guess would be in the word "code", LT doesn't do code, LT has no access to any of the programming api's . If this is an installation issue then I believe that is another issue and would be best addressed in the installation forum. But in LT paths are set using the options dialogue and have to be done manually.
in reply to: steven-g
I should have posted this in "AutoCAD Customization"
cadffm
If this is the right forum, then you can stop asking, because .... read stevens answer again.
I guess you want to install AutoCAD LT themselve? Then the Installation and Licensing Forum should be the right one!
Sebastian
I reposted this with more details here: https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/unable-to-set-support-file-search-pa...
Thanks telling me this was the wrong forum.
steven-g
Its not so much that it is the wrong forum, just that the people who answer questions tend to browse just certain forums, and on specific questions, it can get you a quicker answer by posting in places where you are aiming at a target group of users. Often admin will move posts or you get lucky and find someone who knows or at least can offer advice.
Technology Administrators
