AutoCAD LT Forum
Stationing for 2D lines
6 REPLIES 6
3869 Views, 6 Replies
I'm using ACAD LT 2014 and need to add stationing to lines.  Is there a functionality for creating an alignment and stationing in LT or will it require an upgrade to ACAD  or ACAD 3D?
6 REPLIES 6
Charles_Shade
Stationing? New term for me.
2D survey information or elevations perhaps?
ACAD Full is 3D capable
Sorry - using to my own terminology.    Station labels 1+00, 2+00, etc. along an alignment.
pendean
TEXT command perhaps: to 'align' you could use DIVIDE or MEASURE commands with the text as a block first, then explode the blocks and edit each manually.
AutoCAD is the same way: 'upgrading' only gets you access to the ability to write your own programming code to automate the process with Lisp, VBA and other languages.
Charles_Shade
Creating an Attributed Block might speed that ip a bit.
I do much the same thing for my wife on the pond plans she designs.
KateMorricalTowne
I believe alignments and stationing are Civil 3D features. If you're doing a lot of infrastructure design you might want to check it out instead of LT.
Kate Morrical
Digital Design Manager, Washington DC
BIMmuse.com
in reply to: pendean
Civil 3D gives you the ability to create an alignment as well as a label style to automatically generate the stations. You can also create a viewport group that automatically runs along the alignment.
Forma Design Contest
Technology Administrators
