AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Double-clicking a DXF file opens a new instance of AutoCAD LT 2020
7 REPLIES 7
Message 1 of 8
1465 Views, 7 Replies
When double-clicking a DXF file in Windows Explorer (not when opening it from within AutoCAD LT 2020), each drawing launches in a separate instance of AutoCAD LT 2020.
7 REPLIES 7
Message 2 of 8
pendean
Does this happen with DWG files by chance?
Find out which application Windows is set to use to open your DXF file, then compare when you do the same for DWG file: are they different?
Message 3 of 8
in reply to: pendean
No, this does not happen with DWG files.
Yes, they are different: Windows is set to use "AutoCAD LT Application" to open our DXF files and "AutoCAD DWG Launcher" to open our DWG files.
Message 4 of 8
pendean
They need to be the same I believe, "AutoCAD DWG Launcher" .
Message 5 of 8
You believe correctly. We tried that and it worked. Thank you.
Message 6 of 8
orders
hi! I am experiencing this issue, but I cannot select DWG launcher for DXF files; I can only set DWG to open with DWG launcher. When trying to set the default program for DXF files, DWG launcher isn't even an option. Any ideas?
Message 7 of 8
pendean
in reply to: orders
Choose your primary DWG program for dxf files.
Or get in the habit of using OPEN command from inside our AutoCAD software.
Message 8 of 8
in reply to: orders
Technology Administrators
