When double-clicking a DXF file in Windows Explorer (not when opening it from within AutoCAD LT 2020), each drawing launches in a separate instance of AutoCAD LT 2020.
Solved by pendean. Go to Solution.
No, this does not happen with DWG files.
Yes, they are different: Windows is set to use "AutoCAD LT Application" to open our DXF files and "AutoCAD DWG Launcher" to open our DWG files.
hi! I am experiencing this issue, but I cannot select DWG launcher for DXF files; I can only set DWG to open with DWG launcher. When trying to set the default program for DXF files, DWG launcher isn't even an option. Any ideas?
C:\Program Files\Common Files\Autodesk Shared\AcShellEx
