I'm using ACAD LT 2014 and need to add stationing to lines. Is there a functionality for creating an alignment and stationing in LT or will it require an upgrade to ACAD or ACAD 3D?
Stationing? New term for me.
2D survey information or elevations perhaps?
ACAD Full is 3D capable
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Creating an Attributed Block might speed that ip a bit.
I do much the same thing for my wife on the pond plans she designs.
I believe alignments and stationing are Civil 3D features. If you're doing a lot of infrastructure design you might want to check it out instead of LT.
Civil 3D gives you the ability to create an alignment as well as a label style to automatically generate the stations. You can also create a viewport group that automatically runs along the alignment.
