AutoCAD LT - changes to dim scale linear property in paper space.
Been experiencing this problem occasionally over the last few years, especially since leasing LT a few years ago, but it seems to be getting worse lately.
Dimensions will be correct, but then the dimension will change on its own to some crazy scale - such that a 7'-6" dimension turns into 147'-3 5/8". It is so random, that it will happen in one drawing, but not in others. The change can happen after going from one layout to another, or from model space to the layout, or even just regening the layout.
We only use one dimension style. This is NOT related to selecting model/paper space objects, or annotative/not annotative. We've been using AutoCAD since the 1980's, so we are well versed in the difference. It's a bug in AutoCAD that needs to be fixed.
At this point we are doing a "match property" over all dimensions in a layout prior to every print job and before closing a drawing, to fix the problem. If anyone know of a solution it would be greatly appreciated.
Solved by pendean. Go to Solution.
I experience the same problem when DIMASSOC is set to 2. Changing it to 1 solves the problem. This solution always works for me.
Best regards.
Thanks for the suggestion. I'll give it a try, but I think I want associative dimensions. Isn't that why this tool is available, so it can be used?
I’ve also experienced what I think is either the same or a similar issue, and I think I can explain how to replicate it.
I’m curious if anyone else can replicate this issue.
Edit 1:
Just had a coworker verify that he is able to replicate this, however, we discovered the ability to replicate is dependent upon the method of changing the scale of the first viewport.
Edit 2:
Just noticed this thread is for AutoCAD LT, I’m actually using AutoCAD 2022.
Edit 3:
It looks like the step of matching properties from one viewport to the other is unnecessary. The viewports just need to be created per the directions in edit 1, and properties matched from one dim to the other.
