AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
"Error starting program, A required .DLL file, AC1ST15.DLL, was not found."
6 REPLIES 6
548 Views, 6 Replies
After sucessfully loading auto cad 2000 lti, i get this message when trying to start the program. This file does exist in the following location C:\Program Files\Common Files\Autodesk Shared. Can anyone help me fix this problem? Thanks for your help in advance.
Sincerely, Paul Sepe
6 REPLIES 6
http://support.autodesk.com
Select LT from the pulldown
Type AC1ST15.DLL in the search box.
Read what comes up.
Dean Saadallah
Add-on products for LT
http://www.pendean.com/lt
Just installed Norton...??
In changing computers & reinstalling from disk, error msg ,dll not found
pendean
What version of autocad/lt are you trying to install?
What version of Windows are you installing it in?
Emmsleys
Hi @Anonymous,
Were you able to find a solution or a workaround? Did any of the posts in the thread help with the issue?
Post back if you need continued help with AutoCAD LT.
Sarah Emmsley
Technical Support Specialist
Emmsleys
I'm following up on my previous post. If you have any questions about my post let me know.
If you still need suggestions or have questions I'll be more than happy to help.
Thanks.
Sarah Emmsley
Forma Design Contest
Technology Administrators
