Hi people!!
I have ACAD LT 2018.
I need to have a polygonal viewport, not a rectangular one.
How can I do it?
Thank you,
Chris B.
Solved by cb94030. Go to Solution.
Solved by steven-g. Go to Solution.
You need the command 'MVIEW' either pre-draw your polygon and then start the mview command and use the option to pick an Object. Or start the mview command and use the option Polyline and you can then draw your (closed) shape as a polyline.
As a note, this is only for drawing shaped viewports in a Layout.
