AutoCAD LT Forum
.net framework 4.7.2
6 REPLIES 6
3115 Views, 6 Replies
We're still using Autocad 2014 LT, but can upgrade if necessary.  I have a user who also has a program called DocRecord on her PC, which we installed recently to scan and record architectural documents.  It requires .net framework 4.7.2, but this breaks Autocad.  Does anyone know if there's a version (or a patch) which will allow Autocad to work with 4.7.2?
Many thanks in advance for any advice offered.
6 REPLIES 6
john.vellek
HI @Anonymous,
I see that you are visiting as a new member to the AutoCAD LT forum. Welcome to the Autodesk Community!
 I am curious why AutoCAD LT 2014 won't run with the newer version of .NET.  It is my understanding is that newer versions add on to the old code.
At any rate, what OS is being used?Is there a reason to not use the current version of AutoCAD LT (2019).
John Vellek
in reply to: john.vellek
Thanks John! It seems that all versions of Autocad are only compatible with .net up to version 4.6. I found a table HERE<> on your website, which doessn't show any compatibility with 4.7. The OS is Windows 7 pro SP1. When the problem first came up, I uninstalled .net 4.7.2 and installed 4.6. This fixed Autocad, but broke the users version of DocRecord which is on the same machine. Running two different version of .net allows DocRecord to work, but Autocad either crashes when first opened, or soon after when trying to edit a file. We could upgrade, but I'm not sure that will fix the problem.
john.vellek
Hi @Anonymous,
That article is rather old.  I ask about your OS as Windows 10 is running .NET Framework 4.7.2 on my computer and AutoCAD works fine. (2015-2019)
Here is a Microsoft article that will show you how to determine the version installed on your system.
AutoCAD LT 2014 is not designed to run on Windows 10 either so I am curious how your system is configured.
John Vellek
Thanks John. This is Windows 7, so I can see which versions of .net are installed in Programs and Features. It may be that we have to upgrade this user to Windows 10 and a later version of Autocad. If that's the way forward we can do that. Thanks again for your input!
Steve
Mohon Bantuannya, untuk autocad yab\ng support .net 4.7.2
Forma Design Contest
Technology Administrators
