We're still using Autocad 2014 LT, but can upgrade if necessary. I have a user who also has a program called DocRecord on her PC, which we installed recently to scan and record architectural documents. It requires .net framework 4.7.2, but this breaks Autocad. Does anyone know if there's a version (or a patch) which will allow Autocad to work with 4.7.2?
Many thanks in advance for any advice offered.
Solved by john.vellek. Go to Solution.
HI @Anonymous,
I see that you are visiting as a new member to the AutoCAD LT forum. Welcome to the Autodesk Community!
I am curious why AutoCAD LT 2014 won't run with the newer version of .NET. It is my understanding is that newer versions add on to the old code.
At any rate, what OS is being used?Is there a reason to not use the current version of AutoCAD LT (2019).
Sorry, link insert didn't work. it's here --> https://knowledge.autodesk.com/search-result/caas/CloudHelp/cloudhelp/2018/ENU/AutoCAD-Customization...
Hi @Anonymous,
That article is rather old. I ask about your OS as Windows 10 is running .NET Framework 4.7.2 on my computer and AutoCAD works fine. (2015-2019)
Here is a Microsoft article that will show you how to determine the version installed on your system.
AutoCAD LT 2014 is not designed to run on Windows 10 either so I am curious how your system is configured.
