AutoCAD LT Forum
MTEXT Appearing as Lines instead of text
10 REPLIES 10
Message 1 of 11
mark_lee8PAY4
668 Views, 10 Replies
Hi all, recently I have an issue with the mtext in my drawing. Currently it is appearing as a line (or lines for mtext with more than one line). This issue also reflects in the print space when I am attempting to print a copy of my drawing.
10 REPLIES 10
Message 2 of 11
paullimapa
in reply to: mark_lee8PAY4
could you share a sample drawing with this
Paul Li
IT Specialist
@The Office
Message 3 of 11
mark_lee8PAY4
in reply to: paullimapa
Hi Paul, due to my company's strict policy, I am unable to share a copy of the cad file here.
Message 4 of 11
mark_lee8PAY4
Hi, I have copied the MTEXT over to a new file.
The first one is done using the MTEXT command.
Second one is the MTEXT that I copied from my drawing.
The text is only visible when you select them.
Message 5 of 11
hwalker
The text is visible here without selecting on LT 2016. I would try an AUDIT on your drawing and say YES to fix any errors.
Howard Walker
Left Handed and Proud
Message 6 of 11
pendean
No issues here either with your MTEXT with an override font inside it that does not exist in any of your STYLE definitions.
Share with us a screenshot of your ABOUT command pop-up, and your GRAPHICSCONFIG command pop-up too please.
Message 7 of 11
mark_lee8PAY4
in reply to: hwalker
Hello! I did try the AUDIT command, but doesn't resolve this issue.
Message 8 of 11
mark_lee8PAY4
in reply to: pendean
Message 9 of 11
hwalker
At the command line type type GFXD12 change the value to 0. Reboot AutoCAD and then see if that works.
Howard Walker
Message 10 of 11
mark_lee8PAY4
Oh you meant GFXDX12? Anyway it works!
What does the commend do?
Message 11 of 11
hwalker
Makes AutoCAD use an earlier version of DirectX
Howard Walker
Forma Design Contest
Technology Administrators
