Hi all, recently I have an issue with the mtext in my drawing. Currently it is appearing as a line (or lines for mtext with more than one line). This issue also reflects in the print space when I am attempting to print a copy of my drawing.
Solved by hwalker. Go to Solution.
could you share a sample drawing with this
Hi Paul, due to my company's strict policy, I am unable to share a copy of the cad file here.
Hi, I have copied the MTEXT over to a new file.
The first one is done using the MTEXT command.
Second one is the MTEXT that I copied from my drawing.
The text is only visible when you select them.
The text is visible here without selecting on LT 2016. I would try an AUDIT on your drawing and say YES to fix any errors.
Howard Walker
At the command line type type GFXD12 change the value to 0. Reboot AutoCAD and then see if that works.
Howard Walker
Makes AutoCAD use an earlier version of DirectX
Howard Walker
