AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Issue with next point
2 REPLIES 2
scottepps
566 Views, 2 Replies
I just downloaded 2021 Autocadlt and the issue that I have encountered is when I select a point and moving to the next specific location of the point it jumps around.  It does not go direct to a corner with the curser.  The curser is not responsive as it should be.
2 REPLIES 2
rkmcswain
in reply to: scottepps
Perhaps SNAP is on (not object snap).
The F9 key will toggle it off and on.
Turn on ALL of your status bar icons so you can see which ones of them are ENABLED.
R.K. McSwain     | CADpanacea | on twitter
scottepps
in reply to: rkmcswain
It was the hardware accelerator that was in the off position. Once turned
on all things are working fine.
Thank you
Forma Design Contest
Technology Administrators
