I just downloaded 2021 Autocadlt and the issue that I have encountered is when I select a point and moving to the next specific location of the point it jumps around. It does not go direct to a corner with the curser. The curser is not responsive as it should be.
Solved by scottepps. Go to Solution.
Perhaps SNAP is on (not object snap).
The F9 key will toggle it off and on.
Turn on ALL of your status bar icons so you can see which ones of them are ENABLED.
