AutoCAD LT Forum
Insert layout from template
0 REPLIES 0
Message 1 of 1
255 Views, 0 Replies
I started using Acad LT 2010 for about 2 weeks ago.
the problem i'm having is the following:
When inserting an layout from a template normaly i went to insert then layout and then layout from template.
Then you see a window with the avaible dwt files, after choosing a file you get a window with all the layouts which are included in the selected dwt file, from here you can make a selection for the layout.
In LT 2008 this works perfect but now in LT 2010 the window with the avaible layouts does not appear and therefore you have to type the layoutname on the commandline.
This is difficult because then you need to remember all the layout name by head.
I already looked at filedia but this is set to 1.
Strange thing is that the window for dwt selection is diplayed and the next window for layout selection isn't.
Other stange thing is when you don,t select insert layout with you mouse but type layout on the commandline end then choose template you get to see both windows.
Anyone having this problem too?
Kind regards,
Peter
0 REPLIES 0
Forma Design Contest
Technology Administrators
