Hi
i need to scale a ton of drawings, every drawing have a different scale, but al of them have doors, so i'm scaling them using the door as a reference, i'm looking for a way to automatize that scale process with a macross, but i'm having a hard time finding a way to, so here i am, asking for your help
thanks in advance
Solved by pendean. Go to Solution.
Hi Pendean, Thanks for the reply
yeah, the problem is all of the drawings are in different scales, so far i've been trying to automate the process by measuring the door in the drawing, dividing that number by 90cm (the size the door should be) and using the result as the scale factor, i think i should be using: _SCALE, _SETENV, GETENV, and 'CAL. but i'm unable to get the puzzle pieces to fit
the idea is to make the process as automatic and fast as posible, i'm using my keyboard macros program to automate recurrent tasks
You cannot automate, but you can scale relatively to save calculations.
Scale > Select the basepoint > R > pick one side of the door > next size of the door > 90 (if drawing is in centimeters)
