AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Plot Styles Not Printing
9 REPLIES 9
Message 1 of 10
vicrent
284 Views, 9 Replies
I created a Plot Style that assigns a line weight to each color used, but all my lines print, on paper and on a PDF, to the same exact thickness. I have selected my Plot Style under Plot Style Table and have checked "Plot with Plot Styles" under Plot Options.
I am trying to avoid using object line weights.
Any help would be appreciated.
9 REPLIES 9
Message 2 of 10
RobDraw
in reply to: vicrent
Please share as much information as you can that might lead to a solution.
Plot settings
.ctb settings
sample file
etc.
Rob
Message 3 of 10
pendean
Share with us a sample DWG file along with your plot style table that does not work inside that sample DWG file, lets test your own files for ourselves.
Message 4 of 10
vicrent
in reply to: RobDraw
@pendean
I attached my sample file and a picture of my plot settings. The desired Plot Style is called KDC Plot Style. Most of the lines are black, but sume are red or blue. The color is showing up, but the varying lineweights are not.
Message 5 of 10
RobDraw
The .ctb file is necessary for examination.
Rob
Message 6 of 10
pendean
@vicrent wrote:
@pendean
Your DWG is not the problem as I get all black output when using MONOCHROME CTB plot style table, so you might want to open this and your own plot style table and fix it for each and every color
Message 7 of 10
vicrent
in reply to: pendean
Thank you for taking a look. I already tried editing the monochrome palette with no luck, but I can try again
Message 8 of 10
pendean
@vicrent I'm not sure what the challenge is exactly, forgive me: make a copy of MONOCRHOME.CTB, call it whatever you want to call your personal CTB file, then ONLY edit the pen thickness settings for each ACI color number, nothing more.
Use your broken CTB file as a reference for the pen thickness settings. Again, change nothing else.
Boom, problem solved, CTB fixed.
HTH
Message 9 of 10
vicrent
Unfortunately it is telling me that .ctb files cannot be attached
Message 10 of 10
pendean
Technology Administrators
