I created a Plot Style that assigns a line weight to each color used, but all my lines print, on paper and on a PDF, to the same exact thickness. I have selected my Plot Style under Plot Style Table and have checked "Plot with Plot Styles" under Plot Options.
I am trying to avoid using object line weights.
Any help would be appreciated.
Please share as much information as you can that might lead to a solution.
Plot settings
.ctb settings
sample file
etc.
The .ctb file is necessary for examination.
@vicrent wrote:
I attached my sample file and a picture of my plot settings. The desired Plot Style is called KDC Plot Style. Most of the lines are black, but sume are red or blue. The color is showing up, but the varying lineweights are not.
Your DWG is not the problem as I get all black output when using MONOCHROME CTB plot style table, so you might want to open this and your own plot style table and fix it for each and every color
