Why does my file name always include .dwg at the end?
Solved by imadHabash. Go to Solution.
WHERE can you see this?
In WinExplorer? Then because a human named the file like this in the past.
(you or another person added the ".dwg" part to the filename, where you shouldn't add the extension, so it accepted as part of the filename)
Sebastian
Because that's what type of files AutoCAD creates and edits.
@imadHabash wrote:that means that you have a fake drawing names .
I don't even know what that means.
@Anonymous If that is not the actual file extension and a part of the name, most likely someone was trying to change the extension of a .bak file and did not have file extensions shown, thus making it a part of the file name.
