I have been having trouble opening a DX file. When attempting to open the file I get a message of
Hit Enter to continue
See attached screenshot
I would appreciate some feedback on this. Totally lost
Chris
Solved by hwalker. Go to Solution.
OT First: DockON your commandline
OT Second: Use 3 or 4 lines visible
Check your Textscreen for alle messages [F2]
Q: And what is your problem? Acad says "Press Enter", it means you should press the [ENTER] key on your Keyboard..(scnr)
If there is a defect, we need to know the whole message or better: We need the DXF file to solve it (if possible and someone like to spend time to your problem)
Sebastian
Did I understand correctly: You have a DWG,
from the DWG created a DXF and this DXF shows the error?
I am sure the error already exists in the DWG, but there it does not cause such a problem.
If this is the only error, we can fix it.
Sebastian
Have you tried an AUDIT of the drawing and telling it YES to automatically fix any errors it comes across?
Howard Walker
The AUDIT command found 6 errors embedded in the original DWG file
and was able to correct these. Once those were corrected and the file was saved as a dxf file and once I reopened the newly created DXF file, it opened fine.
Appreciate the support and help. Hope I can return the favor one day
Regards
Chris
