AutoCAD LT Forum
TRouble opening a DXF file in ACAD Lite
8 REPLIES 8
Message 1 of 9
552 Views, 8 Replies
I have been having trouble opening a DX file. When attempting to open the file I get a message of
Hit Enter to continue
See attached screenshot
I would appreciate some feedback on this. Totally lost
Chris
8 REPLIES 8
Message 2 of 9
cadffm
OT First: DockON your commandline
OT Second: Use 3 or 4 lines visible
Check your Textscreen for alle messages [F2]
Q: And what is your problem? Acad says "Press Enter", it means you should press the [ENTER] key on your Keyboard..(scnr)
If there is a defect, we need to know the whole message or better: We need the DXF file to solve it (if possible and someone like to spend time to your problem)
Sebastian
Message 3 of 9
in reply to: cadffm
Thanks for the quick response. I hadn't thought of looking at the command
line table. Here is what it shows:
Error in BLOCK_RECORD Table
Invalid symbol table record name: "" on line 15488.
Invalid or incomplete DXF input -- drawing discarded.
It seems that something is happening when I save a file created under DWG
format as a DXF file. I just tested this and it gave me the same result. It
creates this invalid symbol and it crashes out. Have you heard of this
before?
I am attaching the dxf file as well as the original DWG file
I look forward to hearing back from you
Appreciate the help
Chris
Message 4 of 9
cadffm
Did I understand correctly: You have a DWG,
from the DWG created a DXF and this DXF shows the error?
I am sure the error already exists in the DWG, but there it does not cause such a problem.
If this is the only error, we can fix it.
Sebastian
Message 5 of 9
in reply to: cadffm
Your understanding is correct. When I create a DXF drawing to send to one
of my vendors, the error shows up. I have run into this with multiple files
regardless of whether they are small or large. Trouble is that the original
DWG file was created by someone else and has been modified multiple times
of=over the years. I typically purge the file and resave it and I see the
size of the file change significantly. I have tried with and without
purging and I still get the same issue
Herzlichen vielen Dank fuer die Hilfe
Chris
Message 6 of 9
cadffm
Ohne die Datei kommen wir nicht weiter.
Sebastian
Message 7 of 9
hwalker
Have you tried an AUDIT of the drawing and telling it YES to automatically fix any errors it comes across?
Howard Walker
Left Handed and Proud
Message 8 of 9
in reply to: cadffm
The only data I have for the files I had sent to you are what I can get
from the command lines:
Invalid symbol table record name: "" on line 10876.
Not sure where else to look for other data. This is all I can see
When it prompts me to hit enter and I do, it just kills the file
Message 9 of 9
in reply to: hwalker
The AUDIT command found 6 errors embedded in the original DWG file
and was able to correct these. Once those were corrected and the file was saved as a dxf file and once I reopened the newly created DXF file, it opened fine.
Appreciate the support and help. Hope I can return the favor one day
Regards
Chris
Forma Design Contest
Technology Administrators
