AutoCAD LT Forum
FATAL ERROR: Unhandled e06d7363h Exception at 1158a5ch
8 REPLIES 8
Message 1 of 9
813 Views, 8 Replies
AutoCAD keep crashing with the error "FATAL ERROR: Unhandled e06d7363h Exception at 1158a5ch"
Help would be appreciated.
Robert
8 REPLIES 8
Message 2 of 9
pendean
Your AutoCAD version is...?
Your Windows version is...?
Is this a sudden new problem that started today? Or is this a new PC/Installation?
Message 3 of 9
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD LT forum. Welcome to the Autodesk Community!
Do you have the opportunity to submit a crash report when you see this message? If so, can you give me the CER number so I can examine what might be happening?
It would also be helpful as @pendean asked, to know your:
OS
AutoCAD LT version
Graphics Card make and model.
Installation that has been working for quite some time or new installation.
Di dyou just receive some Windows updates or perhaps hardware driver updates.
Please give me some more details and I hope that I can resolve this problem for you.
John Vellek
Message 4 of 9
in reply to: john.vellek
Thanks for the response.
Whenever I try to submit a crash report it just comes up saying "An error has occurred"
OS: Microsoft Windows 8.1 Pro 6.3.9600 - 64bit
AutoCAD is 2018 version O.49.0.0
The computer has a Intel HD 4400
AutoCAD has been installed since April but the issue has been happening since around September
Also no major updates have been installed or hardware changes done to the PC
Thanks!
Message 5 of 9
pendean
AutoCAD 2018 is currently at 2018.1.1 version, go get all the updates.
What triggers the crash? a command, function, sequence?
What changed with your workflows? Perhaps you started doing something in September, could be as dumb as plugging your phone into the PC, or working from an external drive, or... you tell us.
FWIW Software has no moving parts to break, so something did indeed install to break it starting in September: you do run Windows and it is connected to the web, so no point in "nothing got installed" claims these days 🙂
Message 6 of 9
in reply to: pendean
I am not actually the end user that's having the issues.
But we have a GPO in place to prevent any USB devices being plugged into the system (Keyboard and mouse use PS2)
Also all windows updates are pushed out with WSUS and the site where the user is located hasn't received any updates.
The last piece of software besides AutoCAD LT was installed in 2016.
Have you got any other suggestions?
Message 7 of 9
pendean
What triggers the crash? a command, function, sequence? Find out.
Did you sit with the user and observe the crashes? What did you conclude?
Are they repeatable, on demand, or just random?
Do they happen once a day, 10- times a day, every 10-minutes? Or just by starting the program?
Or are all the crashes limited to one file, or a set of file from one source or one folder on the server?
If they are tied to a server: does the crash occur if they are disconnected from it and files are local as a test?
Is this the one and only user of AutoCADLT2018 at the location? Are others having the same issues?
Once more: Software has no moving parts to break, so something changed in the system to break it starting in September
Message 8 of 9
john.vellek
Hi @Anonymous
Is AutoCAD fully patched from the Autodesk Desktop App or from the Account page?
John Vellek
Message 9 of 9
john.vellek
Hi @Anonymous,
I am a bit confused. You indicate that nothing has changed since 2016 but that you have AutoCAD LT 2018 installed.
At any rate, I suggest creating a new Local Admin account on this workstation. Logon with the new user account and see how AutoCAD LT behaves.  I would like to see if the user profile is damaged using this test or if this is a permissions issue caused by GPO that might be too restrictive.
John Vellek
Forma Design Contest
Technology Administrators
