AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Exported drawing file reduces size
3 REPLIES 3
jeremybelcher
191 Views, 3 Replies
When I export my drawing, the scaled measurement is 16 times smaller. The original drawing is 1/16th scale
3 REPLIES 3
pendean
in reply to: jeremybelcher
"export"? Please elaborate on that please, there are many interpretations for that action in AutoCAD.
It is also curious that your issue matches what you write is acceptable: 1/16.
Looks like something was incorrectly input somewhere.
jeremybelcher
in reply to: pendean
So iam taking plumbing dwg drawing from autocad then saved as a dwf drawing that gets imported to my Leica icr80 tablet. When I open up the file on my tablet all the scaled drawings are 16 times smaller
pendean
Did you draw your content at 1:1 scale in AutoCAD? That is required. 1/16" scale is a print scale, not a scale to be used for drafting in AutoCAD.
When you "exported" to DWF, it was most likely printed to DWF, as in a page size and a print scale was determined.
if you accepted the print scale of 1/16", then you created a sheet of paper who's content was 1/16 the size of the original 1:1 in autoCAD.
Or did you print to DWF at a 1:1 scale, which means your content is small enough to fit on a sheet of paper at 1:1 scale?
A DWF is not a DWG or a DWG-like format, it's Autodesk's answer to a PDF basically, in its most simplistic terms.
LEICA Support may have option for you to avoid the DWF process altogether, go ask them for advice on accessing DXF or DWG direct.
Forma Design Contest
Technology Administrators
