Never mind, got it:
Scaling the horizontal and vertical axes separately in an existing drawing
Issue
You want to separately scale the horizontal and vertical axes of an existing
drawing.
Solution
Make a block out of your entire drawing by following these steps:
From the Draw menu, choose Block > Make.
Enter a name for the block.
Choose Select Objects.
Type All and press ENTER twice.
In the Block Definition dialog box, select the Delete and the Do Not Include
Icon check boxes, and choose OK.
From the Insert menu, choose Block and select your new block from the drop-down
list.
Adjust the X and Y scales as needed. Do not select the Explode check box.
Choose OK.
After inserting the block, use the EXPLODE command.
Whatta weird way to do it. Why not just be able to enter
X.XXXX, Y.YYYY
on the command line with SCALE?
Sheesh.
"V Green"
wrote in message
news:6216390@discussion.autodesk.com...
I need to be able to SCALE at different rates
in the X and Y directions.
I thought that STRETCH might work but it
isn't what I was looking for.
Seems like scaling with non-equal amounts
would be something I can do...
