AutoCAD LT Forum
Welcome to Autodeskā€™s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Showing results forĀ
Did you mean:Ā
drawing compare and background mask on mtext
2 REPLIES 2
jghammanMSCD
203 Views, 2 Replies
I found that when there is a background mask on mtext and using drawing compare the background changes to whatever the color is setup for the comparisons.
I am uploading a picture of this.
is this the way it is supposed to work (or is the only way it can work)?
has anyone else had this problem?
or is it a setting I have wrong?
2 REPLIES 2
pendean
in reply to: jghammanMSCD
Sadly that's a known limitation with background masking.
jghammanMSCD
Thanks pendean
that's what I figured
Forma Design Contest
Technology Administrators
