I found that when there is a background mask on mtext and using drawing compare the background changes to whatever the color is setup for the comparisons.
I am uploading a picture of this.
is this the way it is supposed to work (or is the only way it can work)?
has anyone else had this problem?
or is it a setting I have wrong?
Solved by pendean. Go to Solution.
