Dimension text upside down
bidhin_patel
bidhin_patel
My UCS also moves while I am dimensioning. I don't remember if it was happening before but I don't want it.
Please Help.
Thank You
Replies (8)
pendean
Community Legend
Community Legend
Set the commands UCS and PLAN to WORLD first, then find out what is truly going on in your file.
bidhin_patel
Did still the same
pendean
Community Legend
Community Legend
Restart your PC @bidhin_patel
Open an all new blank DWG file, draw and dimension in there: is the issue still present? I suspect not, but you'll have to confirm.
HTH
bidhin_patel
It is happening because when i select points, new axis guides dimension text where to display @pendean
h_s_walker
Your UCS is still upside down. The Y in your first picture should be above the line not below.
Howard Walker
Left Handed and Proud
pendean
Community Legend
Community Legend
@bidhin_patel wrote:
...It is happening because when i select points, new axis guides dimension text where to display @pendean
Once your UCS looks like this (see below) in a new file (or your current one), your issue will go away, see tips I already provided to get there
HTH
bidhin_patel
It is solved i by mstake clicked on DUCS.
pendean
Community Legend
Community Legend
Which year version (and actual AutoCAD version) are you using please? ABOUT command in the program will confirm your software. You appear to be in the wrong forum at least.
