My UCS also moves while I am dimensioning. I don't remember if it was happening before but I don't want it.
Please Help.
Thank You
Solved by bidhin_patel. Go to Solution.
Restart your PC @bidhin_patel
Open an all new blank DWG file, draw and dimension in there: is the issue still present? I suspect not, but you'll have to confirm.
HTH
Your UCS is still upside down. The Y in your first picture should be above the line not below.
Howard Walker
@bidhin_patel wrote:...It is happening because when i select points, new axis guides dimension text where to display @pendean
Once your UCS looks like this (see below) in a new file (or your current one), your issue will go away, see tips I already provided to get there
HTH
@bidhin_patel wrote:It is solved i by mstake clicked on DUCS.
Which year version (and actual AutoCAD version) are you using please? ABOUT command in the program will confirm your software. You appear to be in the wrong forum at least.
