Help! All new lines I draw are dashed not solid
haegglundarch
Observer Observer
haegglundarch
Observer
Observer
All of the lines I draw are showing up dashed. I haven't changed anything about the drawing set-up, yet this has suddenly started happening. I'm choosing the line type by selecting the "make current" tab. But when I draw a line it's showing up dashed and NOT like the line I set as current. I went to Graphics Config and turned off the Hardware Acceleration and that helped for a few minutes, but now the lines I draw are all showing up dashed again. What should I do?
pendean
Community Legend
Community Legend
Do you need to restart your PC?
or RESET LT if you have not done so?
If this is LT2025, does turning off GFXDX12 variable help?
Does this happen if you just change layers to another one in that file?
Does hit happen in ALL files? and if you start a blank new one?
What is your CELTYPE command set to? and what is your layer's linetype set to?
haegglundarch
Observer
Observer
I wasn't familiar with CELTYPE. But yes, it appears the default linetype had somehow switched to a dashed linetype. I've never had that happen before. Many thanks!
