I am unable to utilize my CTB file when I plot. I have verified it is in the correct location: attached screenshot shows results of STYLESMANAGER command display. Are there settings in PAGESETUP or PLOT that pre-select the type of plotter table? Is there something else I should try?
Thanks.
Solved by chick.biker. Go to Solution.
Solved by hwalker. Go to Solution.
Can you show us a screenshot of the PLOT command pop-up where you would be using the CTB file?
It might give a clue as to why perhaps, like your DWG file is set to use STB instead (a DWG file never uses both CTB and STB at the same time).
EDIT: seems you had the same issue a few years back when you also upgraded https://forums.autodesk.com/t5/autocad-lt-forum/missing-ctb-file/m-p/9265212#M180009
HTH
is your drawing using STB files instead? If so at the command line type CONVERTPSTYLES
Howard Walker
This solved it. I started with a blank file pointing to the wrong plot table. Thanks.
