AutoCAD LT 2021, crashed on me 5 times this morning. The first 4 times I was in paper space, working in a viewport that was drawn 3/4" = 1'-0". When I zoomed in to get an endpoint for dimension, AutoCAD froze and after a few minutes gave me a fatal error.
The last time, I thought maybe I could go into paper space and dimension the detail. The program did it to me again, and so I did a reboot of the computer. It has not done it since, but I have had this problem numerous times in the past couple weeks since installing the 2021 version. I was using 2019 previously
Solved by pendean. Go to Solution.
@pendean I am running the 2021.1 update, and I changed my signature (that took a bit to figure out, lol).
I am thinking that it is probably the file. I am thinking a lot of our problems are because we have moved our templates and blocks along as we upgrade and some of these files have probably been created in AutoCAD LT2000 or earlier.
What do you do when you upgrade programs? Do you start a new drawing somehow and set all your "standards", then save it as a template? How can I clean these files up and start from "scratch"?
We have a number of Non-Purgeable items that somehow have probably come from older files. Is there a way to get rid of all these?
