AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
copy to clipboard failed
7 REPLIES 7
Message 1 of 8
566 Views, 7 Replies
Hi!
I'm using Autocad LT 2017 and I'm having problems to copy some files.
Error Message: "Copy to clipboard failed" .
What can be done? Which Object Enabler to use?
Thanks, Hugo.
7 REPLIES 7
Message 2 of 8
hwalker
Welcome to the Forums
What exactly are you trying to copy to the clipboard?
Howard Walker
Left Handed and Proud
Message 3 of 8
in reply to: hwalker
Is a part of a building, for a production layout.
Message 4 of 8
hwalker
Try copying simple stuff first. Maybe a line and then maybe some text.
Also try copying the objects a few at a time
eg
Copy 1. If that works copy 1 and 2, if that works so on and so forth until it doesn't copy then you've found the item which makes the copy to clipboard fail.
Howard Walker
Message 5 of 8
pendean
Can you WBLOCK from that file? Probably not, right?
Is the file from a version of autoCAD called ARCHITECURE or other specialty? Ask the file create to "save as autocad" for you and resend.
Message 6 of 8
The building created from other software?.
See this Link.
Message 7 of 8
Tryed all options, nothing worked.
Evenso, thanks for your support
Message 8 of 8
I don't know that your computer is installed with Avecto Defendpoint.
It causes copy & pastes error.
See this Link
When you copy & paste, Try using command instead of the shortcut.
Ctrl + C is COPYCLIP
Ctrl + V is PASTECLIP
Technology Administrators
