AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Does BIM 360 Glue run on AutoCAD LT?
5 REPLIES 5
Pshupe
820 Views, 5 Replies
Does BIM 360 Glue run on AutoCAD LT?  Thanks
Regards Peter.
5 REPLIES 5
john.vellek
in reply to: Pshupe
HI @Pshupe,
AutoCAD LT does not accept add-ins so you will not be able to publish to Glue.  Although, you can certainly upload your file in the Glue desktop app.
John Vellek
john.vellek
in reply to: Pshupe
HI @Pshupe,
I am checking back to see if my post helped you with your problem or question. Please mark a post or posts as accepted solutions if they resolved the issue or give me a bit more detail on this issue so we can continue to work towards getting this solved.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
Pshupe
in reply to: john.vellek
I received a contrary answer on the BIM 360 Docs forum.
Regards Peter.
john.vellek
in reply to: Pshupe
Hi @Pshupe,
I will check with @anil_mistry about his answer as soon as possible. He is currently out of the office.  I did consult with Glue support and they confirm my answer however.
As a test, I went to the link for the BIM 360 Add-ins and there is no add-in available for AutoCAD LT (only for AutoCAD).  I also tried that add-in but it will not install in LT.  Lastly, I went to the Windows Control Panel > Programs. I selected each of my LT product versions and used change to try to modify my installation an add the plugin to no avail.
So, in my best informed opinion, the answer is still no, the add-in will not work inside of AutoCAD LT.
I am sorry for the confusion.  I will post any other information I receive from Anil.
John Vellek
pendean
in reply to: Pshupe
>>>...I received a contrary answer on the BIM 360 Docs forum...<<<
May I ask why you want to use Bim360Glue in AutoCADLT? LT is not able to generate models that BIM360Glue can use, AutoCADLT has no BIM abilities, you cannot use it with BIM-capable partners on a project.
Are you perhaps thinking of REVIT-LT instead? Or maybe just Bim360 Docs or Team?
Technology Administrators
