Hi!
I'm using Autocad LT 2017 and I'm having problems to copy some files.
Error Message: "Copy to clipboard failed" .
What can be done? Which Object Enabler to use?
Thanks, Hugo.
Welcome to the Forums
What exactly are you trying to copy to the clipboard?
Howard Walker
Try copying simple stuff first. Maybe a line and then maybe some text.
Also try copying the objects a few at a time
eg
Copy 1. If that works copy 1 and 2, if that works so on and so forth until it doesn't copy then you've found the item which makes the copy to clipboard fail.
Howard Walker
