Converting multiple pdf to dwg
Message 1 of 11
Hey everyone,
I've got 20 pdf files, each contains approx. 100 pages and I need to convert all of them to dwg. Is there any solution I could manage it apart from manually converting pages one by one? Thx much for any suggestion.
Replies (10)
Message 2 of 11
maratovich
No problems. Use this:
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
Message 3 of 11
Thanks much, nevertheless there is one more problem. When I start AutoViewport, select files and click start, it shows error "unable to open and connect autoCAD", although I've got it installed and even opened. I'm using autoCAD 2020 trial version. Is there a way to solve this?
Message 4 of 11
maratovich
I apologize, I did not pay attention to LT - this is only for the full AutoCAD.
In LT it is not possible. Nothing works in it - there is no lisp, no vba, no other programs.
www.kdmsoft.net
Message 5 of 11
pendean
Community Legend
Community Legend
You will need to purchase a standalone 3rd party converter: LT has no such ability and LT by design does not work with AutoCAD add-ons (part of the discount pricing that is the software).
OR... find an intern for the week.
Message 6 of 11
Johneng
You could write a simple script file. Something similar to this. Just change the file name and insertion point for your specific PDF file needs. You can use the attached txt file as a starting point. Modify for your needs and then change the extension to scr. Then run the script command.
-pdfimport
"C:\Users\YOUR PDF FILE PATH HERE.pdf"
1
0,0
-pdfimport
2
10,0
-pdfimport
3
20,0
-pdfimport
4
30,0
-pdfimport
5
0,12
-pdfimport
6
10,12
-pdfimport
7
20,12
-pdfimport
8
30,12
Message 7 of 11
arshdeepsingh404
Here is another way to import multiple PDF pages into AutoCAD at once Importing multiple PDF pages into AutoCAD
Arshdeep Singh
Electrical Designer & Programmer
C.Tech | CAPM | CMSE | Autodesk Expert Elite
LinkedIn | Autodesk App Store | GitHub
Did you find this post helpful? Please feel free to Like this post.
Did your question get successfully answered? Please click the Accept Solution button to help other users who may have the same question.
Message 8 of 11
pendean
Community Legend
Community Legend
@arshdeepsingh404 Nice tip, seems to work well in the LT2025 variant.
Message 9 of 11
arshdeepsingh404
@pendean Thanks Dean for checking it in AutoCAD LT as well, I am glad this works on both platforms.
Arshdeep Singh
Message 10 of 11
bim.gedung.051
Observer
Observer
thanks, you make my life so much easier.
Message 11 of 11
arshdeepsingh404
Arshdeep Singh
