AutoCAD LT Forum
Command Line not movable
9 REPLIES 9
Message 1 of 10
728 Views, 9 Replies
Acad 2017 LT  Command line was docked.  Somehow became undocked and shows up transparently and overlapping the model / paperspace button at the bottom of the screen.  I'd like it to be docked. Any ideas?
I've was seeing script errors for certain commands earlier, not sure if it's problem or that I need to learn the new version.
9 REPLIES 9
Message 2 of 10
rkmcswain
Dock it.
Make sure LOCKUI = 0, then grab the wide edge with a left mouse click and drag it until you see it change to an outline, then release the mouse button.
Message 3 of 10
in reply to: rkmcswain
Thanks.  Confirmed LOCUI = 0.  Doesn't seem to be grabbable in any way that I can figure.
When I make the autocad window so that it is smaller (not maximized), the text still shows up OUTSIDE of the autocad screen, partially below the windows buttons at the bottom of the screen (windows 10).
Message 4 of 10
rkmcswain
Here is an animation of me doing it.
Message 5 of 10
nice animation. Thanks.  That's not at all what I'm seeing on my computer.  I have translucent text, no boxes or anyting like that.
Message 6 of 10
I'm thinking there was an error with my installation and I'll need to give up some hours and reinstall.
Message 7 of 10
Partially solved had to reset acad settings from start menu.  some installation issues seem to remain. Stalls on use of F- Keys and such.
Message 8 of 10
pendean
Ensure LT2017 is fully patched and updated https://knowledge.autodesk.com/support/autocad-lt/downloads
Set TEMPOVERIDDES from 1 to 0 for F-key problem.
Message 9 of 10
Good to know. Thanks!
Message 10 of 10
in reply to: pendean
After full uninstall and reinstall of program, F-keys worked great...until...all snap settings were turned on, which replicated prior stalling issue.  Just used your advice, changing setting from 1 to 0 and seems to work beautifully.  Thanks!
Forma Design Contest
Technology Administrators
