Autocad LT cannot continue
Message 1 of 13
While working in autocad LT suddenly it got crash with this error.
Replies (12)
Message 2 of 13
äcäp
What was the last command or action you made before the error took place?
Message 3 of 13
ennujozlagam
@Anonymous hello, have you try to audit your drawings and save and try to open again and see if helps. thanks
Message 4 of 13
within 3 to 5 mins this error will appear on screen & autocad crashes.
Message 5 of 13
@ennujozlagam it's not a file specific issue. whichever files we open another 3 to 5 mins the autocad crashes with that error message.
Message 6 of 13
pendean
Community Legend
Community Legend
What is your LT version?
It appears you are using Windows7: what else is new of has changed on your PC about the same time these 3-5minutes crashes started?
Message 7 of 13
Emmsleys
Hi @Anonymous,
If possible can you provide more information on your setup?
  • As previously asked what AutoCAD LT versions are you using?
  • Can you provide an NFO file? (AKN help file for NFO file)
  • Have you tested AutoCAD LT logged in as a new user on your system (with full admin access)? Does the issue happen in that environment as well?
Sarah Emmsley
Technical Support Specialist
Message 8 of 13
äcäp
If it is not a file specific issue, that means this error will pop-out even when you open any other files or new drawings, is it?
Well for me, this error could be general. Either drawing files, system, or maybe the software itself. Normally if i'm facing the same error, I will first check the drawings for any reason suspected to cause the error. Sometimes hatch patterns could also be the 'culprit' causing such error 😄
Mind to share your cad dwg file(s) so we can 'investigate' further to find solution?
Just my 2 cents 🙂
Message 9 of 13
@pendean
In both the 2017 & 2018 version the error appeared. the OS is windows 7 SP1.
Message 10 of 13
Hi @Emmsleys
I attached the NFO file of the system.
Message 11 of 13
pendean
Community Legend
Community Legend
Not enough information for remote assistance: also, you need to post the entire NFO file, not a screenshot of one page. Here is how you do that https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Obtain...
Message 12 of 13
Emmsleys
It'll be helpful if you could attach the entire file for the NFO. That way we can look at what other startup programs you have running, whats crashing, system specs, etc.
Please let me know if you are unable to upload the file or feel uncomfortable doing so.
Thanks.
Sarah Emmsley
Message 13 of 13
Emmsleys
Hello @Anonymous,
Following up on your thread, were you able to find a solution or a workaround?
Did any of the posts in the thread help with the issue?
Please use the Accept as Solution for those post’s that helped. It may benefit other users who might have a similar question or issue.
Or post with any new updates if you need continued help on your thread.
Thanks for your time.
Sarah Emmsley
