@Anonymous hello, have you try to audit your drawings and save and try to open again and see if helps. thanks
within 3 to 5 mins this error will appear on screen & autocad crashes.
@ennujozlagam it's not a file specific issue. whichever files we open another 3 to 5 mins the autocad crashes with that error message.
Hi @Anonymous,
If possible can you provide more information on your setup?
It'll be helpful if you could attach the entire file for the NFO. That way we can look at what other startup programs you have running, whats crashing, system specs, etc.
Please let me know if you are unable to upload the file or feel uncomfortable doing so.
Thanks.
Hello @Anonymous,
Following up on your thread, were you able to find a solution or a workaround?
Did any of the posts in the thread help with the issue?
Please use the Accept as Solution for those post’s that helped. It may benefit other users who might have a similar question or issue.
Or post with any new updates if you need continued help on your thread.
Thanks for your time.
