I was just wondering whats the major difference in importing pdfs to a drawing using Xref PDF Import Vs. PDF Import in autocad 2017.
which one one should I use to import pdfs to drawing?
Solved by cadffm. Go to Solution.
Solved by john.vellek. Go to Solution.
Hi @javier.zavala,
If I understand your question correctly, you want to know the difference between PDFAttach and PDFImport.
The latter will allow you to import the PDF content as AutoCAD geometry if the PDF was vector based. PDF Attach will allow you to attach a PDF as if it were an image file.
Hi @javier.zavala,
Sebastian
Sebastian
the example you gave was helpful thank you
