How to change system variables (PICKSET) / Delete key not working
Themeepclub
Themeepclub
I see Autodesk already posted about the problems with the delete key not working and how to solve it. However, I am having trouble solving the issue.
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Select...
I am having the same issue as listed but I'm having trouble solving it. How do I set the PICKFIRST system variable to 1? Where even is the command line located? I see there is a text command box but inputting "pickfirst" does nothing.
Any ideas?
imadHabash
PICKFIRST is a system variable that must work and appear in your command line . please try REDEFINE command then enter the name of your missing command
Command: REDEFINE
Enter command name: pickfirst
if not fixed please try check the box from OPTIONS command >> Selection tab .
Imad Habash
cadffm
The commandline function is everytime working,
if visible or not.
ESC
ESC
Pickfirst <enter>
1 <enter>
CTRL+9 toggle the commandline, or command: commandline/commandlinehide
F2 fir Textscreen
I am thinking you are using the dynamic input feature now,
F1 - DynMode
(F12 toggle this mode on/off)
Sebastian
Themeepclub
Thank you for your reply,
I am still having trouble seeing / finding where the command line is located or the options window in the screenshot you included.
I have included a screenshot of what I see. So far I have managed to find a Text Commands box, but not of the suggested commands work in there.
Themeepclub
Thank you for the response,
Unfortunately none of those solutions worked for me. I tried every one of those keys /combos and nothing popped up or visibly changed. CTRL +9 nor imputing the command changed anything.
I  included a screenshot of what I see. I did eventually find a Text Commands box but no commands I was told to use work
cadffm
You posted in a Autocad-Forum and linked to a Autocad thread,
but you are using Fusion, thats curious.
https://forums.autodesk.com/t5/fusion-360/ct-p/1234
PS: The area near ti your desktop looks like a commandline.. but thats the commandline of fusion and not autocad
Sorry for you.
Sebastian
Themeepclub
....*facepalm*..
Dont know how I didn't recognize that. Thanks for linking me in the right direction
