AutoCAD Forum
.XLG File AutoCAD 2025
2 REPLIES 2
ryan_scott_KA
244 Views, 2 Replies
Since installing AutoCAD 2025 everytime I save my dwg I get a new/updated .xlg file. It says its an Xref log file.
The file is the same name as the parent file but is twice the size and contains a log of the most recent Xref functions
system variable XREFCTRL =0
I cant figure out how to turn it off, can anyone help me out?
2 REPLIES 2
cadffm
in reply to: ryan_scott_KA
Run the 'Reset to default' option and use the 'Export Settings' option.
Still the same issue? With Administration rights,   Clean uninstall, clean new Install.
I guess you used the migration from previous version feature, is it possible?
Don't use it now.
"XREFCTRL" Unknown
XREFCTL is Xref logs on/off
Sebastian
Thanks mate that worked.And yes it was XREFCTL not what I wrote.
Forma Design Contest
AutoCAD Beta
